Kopteristi
Finland
Mike-the-cat Posted at 2017-3-23 07:49
If you have successfully updated the aircraft, the battery that was installed at the time you upgraded will have its firmware updated. That 'inconsistent firmware found' message appears if and only if you insert a non-updated battery.
If you see this, do not touch the 'go fly' button until the update is completed. You CAN override the updating process BEFORE it begins but your battery firmware will have to wait for another time before it is upgraded.
Yep, I don't fly if update is started and this time I don't update until I see what exactly is to be updated. I never saw what was updated when inconsistent firmware was shown and updated as recommended.
It just would be good to know where that info is located what is going to be updated. Where is that info on DJI Go 4 ?.
Yesterday when I planned to turn every stone on software to find this info which modules has inconsistent firmware and is recommended to be updated message of course didn't appear. |
