leonardrosser
Indonesia
Mobilcams Posted at 2017-3-18 08:32
I mean while you aren't flying.. There is a proceedure for it, it's on page 35 in the manual. This may help you restore a dependable link between your phantom and its controller.
okay worth the shot.
yesterday I try the RTH in a quite small field. I set it at 20m, when i do the RTH the aircraft is at 30ish M. it just flew back in current height and when it is reach the home point it flew higher, but i put the throttle down and it land. Why does the aircraft initiate to fly higher than that? but more than that another 3 test of RTH just went normal (while aircraft is within the remote range).
Other than that, did it normal when i press the rth on the remote, it just land? not going back home.
the settings of rth is back to homepoint(100% sure) I press 3 second hold on rth in the remote. single press to the button don't do anything. |
