Audio from your phone is lost on download of original file
2156 10 2017-3-17
Jonnywoods
As the tittle says I down loaded the actual vid from the mavic and now the audio that was recorded is gone where is it saved can I find it somewhere ?
2017-3-17
Ex Machina
Flight distance : 1806362 ft
It was in your downlink video cache, and might still be there.
Hook up your phone to iTunes, select the phone's Apps settings and scroll down till you see DJI Go 4, click on that, and then a list of files and folders will show up on the right. Drag and drop the Video Cache folder to your desktop and then look in that folder to see if the audio version is still there.
Good luck!
2017-3-17
DroneFlying
Flight distance : 10774613 ft
The audio from the phone isn't included in the video captured by the Mavic, but you can download and synchronize it with the video from your Mavic's SD card if you want.
2017-3-17
Jonnywoods
Thanks ex machina that's exactly what I'm looking for I'll go try that !!!
2017-3-18
Jonnywoods
It's a shame it doesn't attach the audio when you down load it to your phone because if you wanted to use it doing a quick edit just on your phone you can't
2017-3-18
pedrodinis
Flight distance : 896476 ft
Portugal
Ex Machina Posted at 2017-3-17 16:15
In iTunes, I can´t see a list of files and folders of an app anywhere. Can you explain it better?
Thanks!
2017-3-18
SteveDickin
Flight distance : 776007 ft
If you attach your iPad/iPhone to a PC, you can choose the option to view files and folders.  The video is in one of the folders along with any photos you took with your iPad/Iphone..  I found mine recently it was in a quite obvious place.
2017-3-18
pedrodinis
Portugal
pedrodinis Posted at 2017-3-18 08:55
Thanks!
I just found the files and folders! The only folder i found that contains audio is the "export works", but it doesn't have the audio files alone. Is there a way to get ONLY the audio files from cache?
2017-3-18
pedrodinis
Portugal
SteveDickin Posted at 2017-3-18 09:02
I use a macbook pro with iTunes. I've already found the files. Thanks!
2017-3-18
Jason Lane
Flight distance : 260144 ft
Philippines
pedrodinis Posted at 2017-3-18 09:17
I don't believe the app records the audio to a separate file. Just add the cache video as a 2nd track in your video editor, making sure it's below the main video track, so it doesn't get displayed. Alternatively, most video editors (eg. iMovie) have an option to "Detach audio" from a video track.
2017-3-18
Ex Machina
Export Works is for movies saved with Editor, you want to the mp4 files stored in videoCache, and no, there are no audio-only files to be had -- it's all audio tracks added to downlink video.
2017-3-18
