a fixed drone is not really a fixed drone/ please read
513 20 2017-3-17 20:45:19
Emilcaruso
Hobbyist
Flight distance : 18960
if you plan on sending your Inspire 2 in to DJI for repairs, be sure to photo your SN number, and make it clear you want YOUR inspire returned. DJI reserves the right to "replace" if they feel fit. the problem with this policy is, the license key will no longer be activated on your Inspire. I needed only a simple repair, yet I got back a refurbished model, they claim they did not do this, but I have proof they switched it on me.
I have been going back and forth for 2 plus weeks and have got nowhere with support.
I currently do not have a license that I paid 1300.00 for.
Don't let this happen to you.
2017-3-17 20:45:19
Runi
Hobbyist
Flight distance : 327582
That is what happened to me to. I sent mine in for minor repairs when the fpv camera stopped working, there was also malefunction on the controller. What I found odd was that I got a totally different drone (new serial # and my registration label was gone), but they sent me my original controller back. I am guessing its a refurbished model since this drone has some issues as well (se another thread for video where it vibrates like mad).
And like you my licenses where gone and it took me around 5-6 days to get them to open op for the license. It was by no means easy and I had to constantly push for answers. Finally I manage to get online chat to help my, it took around an hour and half of constant chatting.
What irritates my about this is that if they just "swapped" my drone with a refurbished (not new) drone, why did I have to wait for almost 4 weeks looking at the status going from "being repaired" to "undergoing flight test" if they then just send me another one. The responce time should be much quicker.
And what also funny is that the controller that actually is the one I bought was not repaired well and it now has som noice coming from the fans inside it, like something is toughing it.
I bought my drone in early January and have only managed to fly on 2 occasions (4-5 flights in total).
What makes me disappointed is that they misinform quite often. When I confronted them with the they say it will take 2-3 business days for them to register the drone. I could se on the package tracking that the drone was delivered to them on the 07 of February but they state the they did not receive it until the 13th of february. How convenient for them to have all those extra days to work with.
2017-3-17 23:13:55
Runi
Hobbyist
I am really starting to question their quality check its amazing that a controller that makes rattling fan noice and a drone with severe residence vibration can pass through as being ready for shipping.  The actually even swapped out my case with a new one that is worse then the one I had, the locking levers on this one are much harder to close and dont match up as well. I had a foam insert inside mine that came with my extra controller and it did not get moved over and DJI says they can't do anything about it and can't send me a new one.. Honestly, you can't send me a peace of foam!
2017-3-17 23:28:40
lvK0bgqCXaWs
Hobbyist
Wow, they are really losing it at DJI. Aren't they aware that,this way, you lose your customers....
2017-3-17 23:42:10
Donnie Stugots
Flight distance : 862765
Wow , that is not right.  I sure hope you get to the bottom of this .  That was a great idea on your part to take the pictures for proof.
I dont understand simple problems like this , It should be so easily resloved.  I mean clearly you have the proof and in additon suddently your Lic. No longer works .
DJI is great in some respect and not so great  in others .
donnie
2017-3-18 04:35:51
Runi
Hobbyist
Donnie Stugots Posted at 2017-3-18 04:35
Wow , that is not right.  I sure hope you get to the bottom of this .  That was a great idea on your part to take the pictures for proof, well played my good man , well played.
donnie
I second that, another solution and the one I did was to scan the QR code on the drone (shows you the serial#, its quite hard to read), the app then stores the number for you , then when you get it back you can double check and se if it is yours.
2017-3-18 04:41:41
fansa84fe8a4
Intern Pilot
Flight distance : 1
Runi, did you ever get the cinema license on the second one you got, i.e. the refurbished one with the different serial?  Looks like you may be getting a third license too with that refurbished vibrator you got on the second repair that needs to go back in.
Looks like you're having a run of bad luck.  Hope the third is a good one.
2017-3-18 08:11:08
RichJ53
Flight distance : 203966
Runi Posted at 2017-3-18 04:41
I take photos of all the QR codes and of the equipment and save this information. It is good for insurance reasons and great to have for proof of ownership. I also keep these records in more than one location just in case of fire.
Rich
2017-3-18 09:21:08
DJI-Jamie
Flight distance : 34239
If the aircraft is replaced, the license would have been transferred to the new unit. Could you please provide the case number so I can follow up?
2017-3-18 20:32:45
DJI-Jamie
Runi Posted at 2017-3-17 23:13
Can you please provide your case number so I can look into this?
2017-3-18 20:35:19
Runi
Hobbyist
DJI-Jamie Posted at 2017-3-18 20:35
HI DJI-Jamie
I managed to get mine resolved so no need for action there. I will how ever have to go through the same process as soon as the replacement drone arrives
My case nr. is: Shipping of CAS-433576-M1N5C7
and the case nr. for the drone that is on the way is: CAS-514729-L7D1D4
2017-3-18 21:42:40
Emilcaruso
Hobbyist
CAS-449103-V8S5L5
this is the 6th or 7th time I have given out this case number to various people at DJI, none of them have done a darn thing..
2017-3-19 06:14:45
nazar404.yahoo
Hobbyist
Flight distance : 76147
Emilcaruso Posted at 2017-3-19 06:14
CAS-449103-V8S5L5
Emilcaruso,
I sent  187 Emails and three days to Finaly get help from the Repair Adminastrator and two extra days to receive a phone call from a DJI Tech ,  Replacement Inspire 2 was returned with no License attached and were using the wrong CineCore Sn:
Almost wanted to personally bring my Drone to California for repair.
All the Best in getting  repair completed.
2017-3-19 06:31:24
Dr Jon
Intern Pilot
Flight distance : 132573
China
CAS-449103-V8S5L5
Do you have Facebook? if you do join the Official DJI Owners Group. The guys here are DJI team and i find very helpful is you approach them in the right manner. I can see from the various threads they do really try to help so give it a go/.....
2017-3-19 06:31:41
fansa84fe8a4
Intern Pilot
Flight distance : 1
nazar404.yahoo Posted at 2017-3-19 06:31
Emilcaruso,
You won't get in if your take it to them in California.  They are behind a locked gate with a security man who only lets delivery trucks through and people who work in the complex.  You can see the closed gate in Google Earth as well if you look.   Must be shipped in.
2017-3-19 08:05:56
Emilcaruso
Hobbyist
Emilcaruso,
I am not given up... thanks
2017-3-19 09:17:19
DJI-Jamie
CAS-449103-V8S5L5
A member from the NA Facility is getting in contact with you to get this addressed.
2017-3-20 10:36:22
DJI-Jamie
Runi Posted at 2017-3-18 21:42
HI DJI-Jamie
I've provided this information to the proper team to see if this process can be a smoother transition for this incoming case.
2017-3-20 10:52:39
hfrancis
Beginner
Flight distance : 8000
I have exactly the same problem. They swapped my Inspire 2 for another one with different serial numbers after it was repaired (didn't recognise lens error after a minor accident) and it came back without the license keys. After a couple of weeks of complaining still no joy, and now they are asking me to return the second drone for this to be fixed.
2017-3-23 12:19:51
hfrancis
Beginner
I have exactly the same problem. They swapped my Inspire 2 for another one with different serial numbers after it was repaired (didn't recognise lens error after a minor accident) and it came back without the license keys. After a couple of weeks of complaining still no joy, and now they are asking me to return the second drone to the Netherlands for this to be fixed (which seems crazy).
They're also asking me for the license keys, but as this was delivered with the keys pre-installed, I'm fairly sure that they were never delivered with the drone. Did anyone else who got an early combo pack (Inspire 2, X5S & Licenses) have the license keys delivered in the box?
2017-3-23 12:20:07
nazar404.yahoo
Hobbyist
fansa84fe8a4 Posted at 2017-3-19 08:05
This is a major problem I believe at DJI in not having the proper training and limited access to the license key information it only granted to a select few  at DJI HQ
This is my personal interpretation after my 187 emails and three days , finally the call I received from a technician with the proper clearance to resolve the issue ,  REPAIR Administrator is the person who can really help you .
If you don't see the correct license key page on the DJI Assitance  2 software then your Cinecore is not recognized in the DJI Servers System which communicates with Assistant 2 software .
Thank God , my inspire 2 is working just great now ..
Best of luck
Neil
2017-3-24 08:42:25
Close
DJI RecommendsPrevious /1 Next
