Imu calibration
1359 12 2017-3-18
FI. Stanley
Flight distance : 148556 ft
Finland
Hi
I have my mavic pro imu calibration on flat surface.
I have also vps cal. via Dji assistant. And gimbal calibration last.
When i flight today drifting more to right a bit and was not even windy.
Here a sample image about my imu result is this right done?.
Thanks for your help!
2017-3-18
thehippoz
Flight distance : 23 ft
Level surface while cold. You want to get it all done before the ac fan kicks on. Mine, gyro 2 is always a little bit high but it flys fine. Might as well do the gimbal cal on same surface
2017-3-18
SkunkWerxs
Flight distance : 231217 ft
My IMU readings are identical to yours
When I have a lock on at least 5 or more satellites it stays rock solid in place ( with no wind )
When in Atti Mode I also have a little -- very small drift to the right ( with no wind )
I think your IMU calibration is perfect I wouldn't recalibrate it
2017-3-18
fansfc84b388
thehippoz Posted at 2017-3-18 13:02
My mavic pro will not take off. The stick will not respond this is the first time i took it out of the box to try and fly it. The remote is saying ready. Please help.
2017-3-18
Tango_B
Flight distance : 2891473 ft
Hi there, did a new IMU calibration solve your issue? I am having a drift problem the same as yours.
2017-3-18
thehippoz
fansfc84b388 Posted at 2017-3-18 17:56
Put both sticks in and down (45 degrees) to start motors
2017-3-18
FI. Stanley
Finland
I did again imu. When hovering at low position is solid also in tripod mode no issues whatsoever. But when I put the Mavic higher I see that a bit right slowly can also be my gimbal cam?.  But when on the ground the gimbal also stay solid and also did gimbal calibration. That why I ask is my result of imu good.m calibration I'm also do on level surface. That again
2017-3-18
FI. Stanley
Finland
SkunkWerxs Posted at 2017-3-18 13:28
Thanks for you advice
2017-3-18
digitalintruder
Flight distance : 3652379 ft
I had a similar issue - but only at night.  had to re-calibrate the IMU / VPS / Compass at different points of owning my device; however none of that really helped the hor/ver drift.
I stumbled on a post stating low light cannot hold steady height. I usually ensure if I'm flying low, it's a well lit area at night. During the day, the mavic holds position like a champ.
Best of luck resolving your issue.
2017-3-18
fans0368fca7
Finland
It's work now fine is solid I did gimbal calibration again and seem be now okey. Thanks very one for your help
2017-3-19
FI. Stanley
Finland
digitalintruder Posted at 2017-3-18 21:33
Was not my aircraft that drifting I found out my cam when hovering. I did cool down my drone for 20min in the basement there is cold I'm living in Finland cold is not a problem here after 20min cool down I'm fire my mavic up start imu calibration and after gimbal calibration and I had no issues anymore it's helps that way.
2017-3-19
digitalintruder
FI. Stanley Posted at 2017-3-19 12:18
Ah nice, glad you resolved it. I'll keep those steps in mind next time this happens.
2017-3-19
FI. Stanley
Finland
digitalintruder Posted at 2017-3-19 20:14
unfortunately I did make some test flight my mavic drifting right and my gimbal don't stop when hover drift to right. I think I have serious issue with my Mavic.
2017-3-20
