bk_flyguy
New to the Mavic Pro. Using some PolarPro ND filters, they are installed correctly.
The footage looks good, but as a pro videographer I scrutinize footage. Is the performance any worse on the gimbal while using a PolarPro filter? I have the Cinema Series shutter (standard ND). Will panning and tilting movements still look just as fluid, or will the slight extra weight cause the gimbal to perform a little less smooth?
Also, I am reviewing footage and I would use the AF tap to focus on a semi regular basis. In the footage, it seems that this causes the camera to do a brief hunt which leaves a sort of artifact/blip in the video. Is this normal? Is it best practice to not "tap to focus" mid shot that you want to use?
