GSI_IRE
Flight distance : 121460 ft
In regards the pilots problem here, its unfortunate the turn of events that occurred, cut him a bit of slack.
But sorry, unfortunately, the hint is in the name. No Fly Zone. The device must land.
In event of this people a plane or helicopter, someone would be in contact, give directions, do X or Y, your in the path of Z, we will guide you out so no one is in danger. Or advise other craft in the area that they need to move away from said plane etc as they have no control of where its flying.
As a drone pilot you don't have that communication, even worse, they probably don't even know your there... which is probably even more dangerous. The only safe option, when INSIDE a NFZ is to land, immediately and without delay.
As for what should happen on approach etc, I suppose I would be of the mind, you should know where your flying, and shouldn't approach a NFZ.
This is in no way a dig at this pilot, we all have to learn, and I have know I have learned from just reading this thread... ITS THE PILOTS RESPONSIBILITY TO BE KNOW WHERE YOU ARE AND DO EVERYTHING TO STAY IN CONTROL OF YOUR DRONE.
@ trica de - I don't expect you will get any response from a MOD, other than maybe, the device was acting as designed when it found its self inside an NFZ |
