Crash my drone. Now my gimbal makes alot of noise!!!
1393 8 2017-3-19
Darrendee81
Flight distance : 49390 ft
Jamaica
Help. Drone fell about 15meters after hitting a tree.
I don't see any exterior damage except for the broken prop guards.
Turn on the drone and the gimbal is making loud noise as if it was updating.
Here is the vide:
Should I be concerned? What can I do to resolve this.
Thanks on advance.
2017-3-19
G_Sig
Flight distance : 9109311 ft
Iceland
Have you looked at this
2017-3-19
Darrendee81
Jamaica
Thanks you very much. Will try that asap!!!
2017-3-19
Darrendee81
Jamaica
G_Sig Posted at 2017-3-19 14:33
Have you looked at this Gimbal
Thank you very much. it fixed the issue. i have another question.....
Should i discard the props. They aren't broken, but i'm not sure if the impact from hitting the tree would have cause it to deform or cause it to be unbalance???
Thanks in advance.
2017-3-20
G_Sig
Iceland
Darrendee81 Posted at 2017-3-20 08:44
Yes it make no sense to save $20 but risk $100 - $200 cost in  repair.
2017-3-20
DJI-Jamie
Flight distance : 112405 ft
It would be best to replace them, since you don't want to risk that the hubs themselves were compromised.
2017-3-20
Darrendee81
Jamaica
So it sees the problem is intermittent. checked it last night and the buzz/vibration came back. made adjustments to the yaw screw again, but didn't make a difference. tested it this morning and the buzzing/vibration was very minimal or close to none existent. i think the issue maybe with the panning motor as its quiet predominant when the drone pitches forward and the gimbals compensates by pointing up.
2017-3-21
G_Sig
Iceland
Darrendee81 Posted at 2017-3-21 05:53
Have you also used camera calibration?
Might help.
2017-3-21
Darrenddmp
Jamaica
G_Sig Posted at 2017-3-21 07:43
Might help.
thanks will try
2017-6-5
