Mobilcams
Flight distance : 2907674 ft
tvl Posted at 2017-3-20 15:28
OK, I have another question or two:
What is the proper or best method for doing a deep discharge? ............... power up the drone and let it run at idle until the battery is drained???? Hopefully there is a better method than this!
There are a few that you can do.. When I did mine, I flew it till it reached 10 percent, then let it idle with motors off for a little while until it was at 8 percent. The batteries ARE smart batteries.. They will cut out when the voltage becomes to low.. The real danger lies in leaving them at that discharged level too long.. Let the batteries cool down then IMMEDIATELY charge them up.. The damage can come from when you do not charge them immediately and the normal discharge of the batteries takes them to a point you will not be able to recover from. |
