slave controller dont work joysticks with gimbal
2199 7 2017-3-19
fans2b56e667
Flight distance : 606152 ft
Chile
I have my inspire 1 pro, and I updated all to last firmware in the master and slave controller, drone, camera x5, batteries and dji go.  But when I want to move the camera with the joysticks in "Slave controller" I can´t. only i can move the camera touching the ipad.
Please help, Thanks.
2017-3-19
Donnie *
Flight distance : 3636782 ft
     Ok , if everthing else works fine with the Slave and Master then I thinkI know what the challenge may be .
Be sure that the Master RC is set to the "Follow "  ( Not FPV or free mode  ) in the gimbal settings of the go app , be sure to confirm this First.  Then go to the Slave RC and open the "gimbal settings " page and confirm that it is in "Follow"  ( Not FPV or Free mode ) mode as well.
I had this happen to me once and it may be what you are experiencing.  I have some other ideas , but try this first and see if it solves the issue.
donnie
2017-3-20
fans2b56e667
Chile
Donnie * Posted at 2017-3-20 05:42
I have all in follow, and nothing , I can change all the camera settings with slave controller.
2017-3-20
DJI-Jamie
Flight distance : 112405 ft
Try resetting the RC by using the following button combination:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller
When setting the RC up as the slave again, ensure that you hit the "request control" button.
2017-3-20
Donnie *
I would do the reset as DJI Jamie suggested and also make sure that both RC are using MODE 2 for the stick configuration .
You did confirm that the Slave and Master were both set to "follow mode"  , make sure the entire system is on when checking as doing it while not connected will not save the setting.
If the above does not work I would go to Advanced gimbal settings and reset them to the default on both the master and the slave , then adjust them to fit your  flying style .
Make sure you are not in "coach  mode" as well on the Master and Slave Transmitters.  Be sure to check this as it could be casing your issue.  Coach mode enables the Slave to act as the Master and if you have this enabled it would cause the same issue you describe.
donnie
2017-3-21
Donnie *
fans2b56e667 Posted at 2017-3-20 12:25
Were you able to figure it out ?   I j keep a log with unique things like this that I can reference at later dates.  If you do find a solution or if one of my suggestions help , please let me know  so I can add it to my  log.
thanks
donnie
2017-3-23
Atti58
Donnie * Posted at 2017-3-23 05:00
thanks
Hello Donnie,
I'm affraid, it was the "coach mode" causing that Problem - so it was in my case. Disabling it solves my problem, that the slave has control about the air craft.
Thanks for your help.
Regards, Atti.
2017-4-1
Donnie *
Atti58 Posted at 2017-4-1 00:17
Hello Donnie,
Yep,  in post #5 above  I mentioned  that, regarding "Coach Mode ."
"Make sure you are not in "coach  mode" as well on the Master and Slave Transmitters.  Be sure to check this as it could be casing your issue.  Coach mode enables the Slave to act as the Master and if you have this enabled it would cause the same issue you describe.  "
****More than likely you figured this out on your own which is sometimes the best way to fix problems, during the dicovery process you learn other things as well that you can  use for future reference .
Glad you have it sorted .
donnie
2017-4-1
