Can I order just this missing part?
1465 14 2017-3-19
theGrindLab.com
Flight distance : 1375846 ft
So, my P4P lost a cover plate of sorts from one if its legs (landing gear). Anyone know if I can order just this small piece of plastic? I have found the landing gear kit for the P4, but I am not sure if it would be the same for the P4P.
http://www.ebay.com/itm/DJI-Phan ... :g:HMAAAOSwFe5XyLh4
2017-3-19
Quamera
Bits for the P4P are fairly hard to source but that little cover plate looks identical to the P4 so if it was possible to buy it separately at least it should be available. If you were close to a dealer they could have a damaged P4 for used parts. There will be 2 pairs of covers, one pair will be a mirror image of the other.
I did try to take off that cover recently to see if my aerial was properly connected (the aerial runs through the legs) but it was too firmly attached so I gave up because I didn't want to damage anything.
Another option would be to wrap a little duct tape around the hole, cheap, easy, waterproof and quite neat if you do it carefully.
2017-3-20
theGrindLab.com
Quamera Posted at 2017-3-20 02:00
Thanks for the info, Quamera.
2017-3-20
DJI-Jamie
Flight distance : 112405 ft
They're normally not available for purchase, but have you tried contacting Support to see if that can be provided to you?
2017-3-20
theGrindLab.com
DJI-Jamie Posted at 2017-3-20 15:11
Thank you. I have not contacted support just yet. I usually get a much faster reply here on the forums than from DJI support, so I posted here first.
2017-3-21
mic75
Flight distance : 3799423 ft
The landing gears is probably the first thing you will have to replace if you have even a minor crash, so wouldn't hurt to buy new landing gear and just use the ones that come with them.
2017-3-21
theGrindLab.com
mic75 Posted at 2017-3-21 05:49
That makes a lot of sense! I suppose that's what I'll do.
2017-3-21
Alyn Walsh
Flight distance : 91407 ft
Why not try an insurance salvage company?  try:https://www.suasnews.com/2016/10/uas-insurance-salvage-next-new-opportunity/
2017-3-21
usere1c0332ac8
Make sure you put a little clear tape over all of them, shouldn't have to but I see alot of people loosing them.
2017-3-23
theGrindLab.com
usere1c0332ac8 Posted at 2017-3-23 05:05
Ah. Very good advice! Thank you.
2017-3-23
theGrindLab.com
Just a heads up. I did what you recommended. Support replied with a request for purchase info. I sent the info. Support replied, said my request would be forwarded to another person/department. That was 3 or 4 weeks ago. No reply since.
2017-5-10
DJI-Jamie
theGrindLab.com Posted at 2017-5-10 12:01
If you have a ticket or case number, I can follow up with it.
2017-5-10
theGrindLab.com
DJI-Jamie Posted at 2017-5-10 14:32
It's not a big issue. I'll buy a landing kit off eBay. Just wanted you to know what happened.
2017-5-11
theGrindLab.com
Another update. The parts arrived today. Support sent me a set free of charge.
Just arrived from DJI!
2017-6-7
DJI-Jamie
theGrindLab.com Posted at 2017-6-7 11:02
Another update. The parts arrived today. Support sent me a see free of charge.
Good to hear, thanks for the update.
2017-6-7
