Sensor Calibration Issue
1367 5 2017-3-19
mfordy
United Arab Emirates
Does anyone have some advice on how to sort out a sensor calibration issue.
Firmware is up to date on all devices.
Unable to do the calibration with the DJI calibration board and DJI assistant 2.
DJI Go App Keeps issuing warnings.
Please see screen shots attached below.
Any tips or advice would be much appreciated, thanks in advance.
2017-3-19
Dr Jon
Flight distance : 463012 ft
China
Have you done a calibration before? Its not as intuitive as the manual says i followed the Assistant 2 and just couldn't get 100% . There is a Youtube video showing how to do it correctly watch that and you will find it easy after that
2017-3-20
Daroga
Flight distance : 3517287 ft
The DJI Assistant 2 program can not tolerate multiple monitors, single monitor must be in landscape and cannot be greater that 1600 x 900. If any of these are configured, then change your display configuration.
Also, for calibration, the Vision driver must load when the aircraft is connected to the USB.
(On a PC, it's the libusb-win32 devices entry in Device Manager with the subkey Vision (Interface 3). Look at it's properties and ensure the device status is "working properly". If it states otherwise, then run the Installer_x64 or Installer_x86 (located in C:\Program Files (x86)\DJI Product\DJI Assistant 2\Drivers\Vision) as appropriate for your system and then reboot everything and try again.)
2017-3-20
DJI-Jamie
Flight distance : 112405 ft
If the calibration keeps failing, have you tried using a different monitor if possible?
2017-3-20
Desert Drone Pi
At first I tried to manage the DJI assistant 2 on my PC and still had no luck. I then used a Apple Macbook with Assistant 2 and was successful to proceed with the calibration process. However once the calibration process was complete and i restarted my inspire 2, I am still getting warning messages on the ipad as seen in the screen shot.
2017-3-21
DJI-Jamie
Desert Drone Pi Posted at 2017-3-21 01:26
Have you tried restoring to factory defaults in the Assistant 2, along with an IMU calibration after the sensor calibration?
2017-3-21
