Custom Joystick Configurations
80 5 2017-3-20 00:54:24
Bando Works
Hobbyist
Is it possible to set your left and right stick as normal, but set the top right scroll wheel to control "roll"??
We have set the controls to control roll via the right joystick, with pan/tilt controlled by left joystick, but wondering if we can keep original stick configuration while adjusting the roll as needed via the wheel (instead of having to go into the menu which takes too long on-the-fly to correct)
Please let us know if this is possible.  Thanks
2017-3-20 00:54:24
Mark Guille
Flight distance : 612833
Jersey
Are you talking about gimbal roll or aircraft roll? Master or slave controller?
2017-3-20 02:19:20
Electro-Nick
Hobbyist
Flight distance : 737360
If you're talking about the I2 and second RC camera control, then you can custom configure the camera roll adjustment to one of the joysticks, but not the wheel - I don't recall seeing it as on option to drag-drop the function on to, and certainly not the right wheel as that adjusts exposure settings.
I did try custom setting the sticks so that the left one adjusted roll while the right did both yaw & pitch, but I found it a bit *too* easy to adjust the roll so have left them at default settings!
2017-3-20 04:20:52
Bando Works
Hobbyist
Mark Guille Posted at 2017-3-20 02:19
Gimbal roll on slave controller..
2017-3-20 11:58:58
Bando Works
Hobbyist
Electro-Nick Posted at 2017-3-20 04:20
Yeah we tried setting the roll to one of the joysticks but prefer the original configuration.  Would love to be able to adjust gimbal roll more quickly than entering the menu
2017-3-20 12:01:16
Electro-Nick
Hobbyist
err - just a thought as I've never thought to  try it yet -  does the C2+right wheel to adjust gimbal roll not work on the 2nd RC like it does on the pilot RC?
2017-3-20 13:04:54
Close
DJI RecommendsPrevious /1 Next
