Lost signal -> no RTH
613 10 2017-3-20
bke
Flight distance : 111716 ft
Hello,
i have been activating the RTH function in case of lost signal on my inspire 2.
After deactivation of the controller, the inspire 2 just landed without flying home.
Is this a bug?
Thanks.
2017-3-20
bke
I forgot to say. All tests before with manual RTH activation where successful. But not in case of emergency.
2017-3-20
Donnie *
Flight distance : 3636782 ft
bke Posted at 2017-3-20 04:56
I bet you were within 20 yards of the Home Point .  Would that be correct ?  If you are within that range the Aircraft will just descend and land , this is normal .
Be sure when setting the Height of the RTH that you  are able to  Just clear the tallest object in the area, any more than that is a waste of battery and when you use  that function you may need all the battery power you can get .
Also make sure that the " Remote Control Siganl Lost" is set to "Return -To -Home"   as there are option for it to Just "Hover"  Or "Land"
*** I just realized you have the Inspire 2.....I have the Inspire 1 but believe these features are the  same.
Hope this helps
donnie
2017-3-20
Dr Jon
Flight distance : 463012 ft
China
Hi Donnie, almost right. but the I2 has intelligent compared to I1 when using return home and if it find something in its way on return flight it will find a way around it. So RTH doesn't need to be the biggest building in the area, it will back track and move around any object that blocks its path. It will remember how it got where it is an d use some common logic to get back home. But your also right if RTH is 20 yards away it will flash a warning on the GO 4 and say to close to RTH and will  hover ... Don't forget it has OA so can see around objects.
2017-3-20
Donnie *
Dr Jon Posted at 2017-3-20 06:20
So I get half the prize money  still  correct?  LOL
I keep forgetting to look if it is Inspire 1 V2 Or Inspire 2. , Oh well I will  figure it out eventually !!
Thanks DJ
donnie
2017-3-20
Alastair
Flight distance : 96631 ft
Donnie * Posted at 2017-3-20 06:37
What's with a the Donald Duck avatar?
2017-3-20
Mark Guille
Flight distance : 2031818 ft
Jersey
Have you done something different with your hair Donnie? Love that bow tie!
Brother Mark
2017-3-20
DJI-Jamie
Flight distance : 112405 ft
Just to clarify, how far off were you from the home point when you conducted the tests?
2017-3-20
DJI-Jamie
Alastair Posted at 2017-3-20 06:48
I'm noticing a few others with Disney avatars now, I wonder if this was a group concensus?
2017-3-20
Donnie *
Just a change up, my daughter thought  Tony Soprano was a bit harsh .
donnie
2017-3-21
Donnie *
Mark Guille Posted at 2017-3-20 06:52
Brother Mark
Dont think I have not noticed you too Mark........
donnie ( donald )
2017-3-21
