chalde
Flight distance : 668314 ft
Litchi works fine with Samsung's phones, to my knowledge. Tested on S7 Edge (with Nougat) and Note 3.
You'll also have access to Google Maps, which is a big plus depending where you're going in vacation. I'm also leaving for vacation in 2 weeks to france and heard that Here was pretty useless there. So I'll plan to use Litchi with Google Maps.
Litchi is pretty straightforward, tho, it's missing the Tripod mode . It does include Waypoints, which is quite easy to use.
My only gripe with Litchi is that there is no "land" button. In some instance, I do like to force the drone to come down to land, at it's given position.
Edit: Forgot to mention that I had read that is anything happen while using Litchi, DJI is likely to Void Warranty - so use at your own risk.
It's a shame truly that the best phones on the market are cripped with a compatibility issue between OS and DJI Go 4 App.
Edit 2: Also found this on the website:
March 7th, 2017 - There is currently an issue with the latest firmware for Mavic Pro (v01.03.0500), Inspire 2 (v01.0.0240) and Phantom 4 Pro (v01.03.0418) where the drone will fly erratically in some of Litchi’s flight modes. If you already installed one of these firmwares, we highly recommend not using these flight modes until the issue is fixed with a DJI firmware update. The following flight modes are affected: VR with Immersive/Joystick Head Tracking active, Follow, Focus and Track. All other flight modes (including FPV, Waypoint, Orbit and VR with Immersive/Joystick Head Tracking OFF) are unaffected.
