Unbelievable flaw leds to epic crash
12Next >
2125 47 2017-3-20 12:17:38
fans453b768c
Beginner
I made a video to explain what happened.
Any hints how to avoid such situations in the future? These Birds are a little to expensive to buy them in bulk.
tobias
2017-3-20 12:17:38
fans90d4f438
Student Pilot
sorry it happened. But you put together a NICE video that's for sure
2017-3-20 12:32:32
tokenbrit
Student Pilot
Flight distance : 2910
Sorry to hear about the crash.  The avoidance system is a great idea in concept, but it's not perfect and at best you can only hope it will save you from an accident if you make an error.
Mine flew into a sign in "follow-me" mode - fortunately I got away with only some broken props. It was however my first crash in nearly 2 years and happened because I relied on the system and wasn't paying enough attention.
2017-3-20 12:50:13
mmee
Student Pilot
Have you ever calibrated the obstacle avoidance system? There is a calibration procedure.
2017-3-20 13:10:53
Scunna
Student Pilot
Keep away from buildings.
2017-3-20 13:18:34
NoSale
Student Pilot
Flight distance : 16251
Sorry for the damage you incurred, but glad you got everything back.
And I do appreciate the detailed, well put together video explaining the circumstances, and response from DJI.
I assume nothing will work as advertised.  But I do fly with more peace of mind believing that there might be some safe guards to oversights on my part.  Regardless, I try to fly conservatively and with caution at all times.
Again, thanks for the informative video.  Hope your future flying is without incident.......
2017-3-20 13:26:00
hallmark007
Ban Posts
Flight distance : 215838
2017-3-20 13:37:07
Poop Chute
Hobbyist
Nice video.  Glad you recovered the bird, albeit somewhat battered & bruised.  Out of curiosity  did you have the RTH altitude set higher than the buildings?  I fly over Baltimore often & always set my RTH for 215m (705') "just in case" as that clears everything in the downtown corridor.
2017-3-20 13:37:33
Danny-B-
Intern Pilot
Flight distance : 69527
Logs?
You sure the home point was set at you? It looks like it was on an RTH path and height was set too low.
Just upload your logs to phantomhelp or healthydrones
2017-3-20 13:38:51
RightStuffed
Hobbyist
Excellent!
2017-3-20 13:59:32
Daroga
Flight distance : 685542
tobias,
Sorry for your experience! That's a real bummer video but also very well produced, Thanks!
The major flaw with this crash appears to be impromptu flying. That's flying without any prior planning. There are two groups of impromptu flyers - those that have crashed and those that will crash.... The greatest flaw for remote pilots is depth perception both in visual line of sight and beyond visual range. At almost any distance, it's difficult to always know if you are in front of or behind an obstacle when flying, climbing or decending. Without minimal prior planning, you're flipping the coin with each flight -> crash or dumb luck....
Now I'm not trying to take any fun away from flying. It's just that aviation comes with risks and it's important for all of us to perform some risk assessment to configure our aircraft, the GO4 App, and to then fly to minimize these risks.
Had you planned to fly aroud that building, you could have looked at Google Earth to see that it appears to be about 125m tall. The futher building is about 30m taller. So you could have been prepared to set your RTH for 150-160m. What was your RTH?
DJI and government aviation agencies recommend remaining in visual line of sight, but more important is our antenna line of sight. Fly behind a hill, a building, a tower, etc and you will loose your connection. Only some of our IOC functions like POC or waypoints allow you to plan a mission and have the aircraft execute that mission even when antenna line of sight may be lost. But even then, you  must set an appropriate RTH height.
So in the future, at least minimally plan your flights, double check your RTH and vision system settings, and know when and where you might loose your antenna line of sight. You can use use obstacle avoidance to back you up, but don't expect it to always bail you out of your pilot respnsibilities as it can be fooled....
As others have noted, the aircraft flight logs will show your settings and the details of the flight.
2017-3-20 14:07:15
DroneFlying
Intern Pilot
Flight distance : 1608322
"You don't fly near buildings. The manual says so."
Maybe so, but "near" is a little vague and in its broadest interpretation could probably be applied to almost all flights. In any case, it'll be interesting to see what the logs show.
2017-3-20 14:30:50
fans453b768c
Beginner
mmee Posted at 2017-3-20 13:10
No, i never did. Didn't know that this is possible or necessary.
2017-3-20 15:19:50
fans453b768c
Beginner
Poop Chute Posted at 2017-3-20 13:37
Yes i did set RTH altitude at 200m here
2017-3-20 15:20:24
fans453b768c
Beginner
Daroga Posted at 2017-3-20 14:07
tobias,
Thanks for your helpful advise around planning. While i certainly was out of antenna-line-of-sight during this flight - i was not when the incident occurred.
2017-3-20 15:22:05
geofox784
Student Pilot
Flight distance : 196749
Sync your records to healthydrones.com and you should get a ton of interesting data.
Download the HD sync app https://healthydrones.com/sync-app
Sync your records to the DJI cloud then follow the instructions in the HD sync app.
2017-3-20 16:17:00
Ex Machina
Intern Pilot
Flight distance : 180430
Nicely put together video about your experience, though I'm sorry you had to make it. Were you flying in Sports mode? OA doesn't work in that mode, fwiw.
Agree with the others, logs should give you clues about why this happened.
2017-3-20 19:20:56
geofox784
Student Pilot
I reconstructed the crash in google earth assuming that this was a RTH sequence.
Based on your video, google earth shows the altitude of your takeoff location to be 160ft.
It appears that it collided the building almost perfectly in line with height of the stairwell structure on the west side of the building. Placing my cursor at that estimated location of impact based on the trajectory just before video loss it shows an altitude of 370ft on the building. 370' - 160' = 210' AGL or 64m AGL.
Conclusion:
The height of the RTH must have been set to ~64m AGL OR LESS. I believe it was less because the AC did not raise altitude when the RTH sequence started. It simply stayed at its current height. This happens when the AC is already higher than the selected RTH altitude. Did you update the firmware recently? The latest update caused the RTH the go back to the default 30 meters.  The highest point of that building is 244' AGL or ~74m.
USER ERROR IF RTH SEQUENCE. - User should have checked RTH altitude before flight and set it to at least 100m.
Front obstacle avoidance was also most likely disabled. It should have easily detected and prevented the impact. Regardless, obstacle avoidance should NOT be used as a substitute for a good RTH altitude.
I also think that the home point shown in the video is not accurate as the AC did not head in that direction and the AC had LOS to the home point at that location.
The logs will help prove or disprove this. Upload them to healthy drones. If they dont show any information after disconnect then send the logs from the AC itself instead of the remote to DJI engineering. They can see what happens after disconnect.
SCREENSHOT FROM VIDEO:
SCREENSHOT FROM GOOGLE EARTH:
2017-3-20 21:03:15
mmee
Student Pilot
geofox784 Posted at 2017-3-20 21:03
I reconstructed the crash in google earth.
Problem with that is the building that he hit is the opposite direction from the Home point.
2017-3-20 21:19:43
Jason Lane
Intern Pilot
Flight distance : 79292
Philippines
No offense, but your conclusion relies entirely on a lot of assumptions. You're basically saying that the OP was wrong or lying about the facts.
- "The height of the RTH must have been set to ~64m AGL OR LESS." He said his RTH height was set to 200m.
- "Front obstacle avoidance was also most likely disabled." Well, the OP seems to believe they were enabled.
- You "think that the home point shown in the video is not accurate."  That's a big assumption, with nothing to back it up at this point.
I agree that if everything you've assumed is true, that would explain the crash. But bottom line, it's not fair to make any of those assumptions without the data. It's fair enough to ask those questions, but you can't say that you've come to a "conclusion" without seeing the flight data first.
2017-3-21 00:07:33
Japan
Did you sent it in for further diagnosis?
Our engineers will help to analyse the flight data inside the aircraft and let you know what could have caused the issue.
2017-3-21 02:41:29
hallmark007
Ban Posts
2017-3-21 04:30:32
geofox784
Student Pilot
Jason Lane Posted at 2017-3-21 00:07
"The logs will help prove or disprove this. Upload them to healthy drones."
Its entirely possible I am wrong. This could all just be a fly away for no reason in a random direction. However if it is a RTH sequence then it was not setup correctly. Need the logs to figure this out.
Also OP thinks that it was set to 200m but its an easy mistake to have it been otherwise. There has been a few other cases of users forgetting the check the RTH altitude setting after firmware updates.
2017-3-21 05:11:44
geofox784
Student Pilot
Made some edits to my wording.
2017-3-21 05:19:39
CuaC
Student Pilot
Flight distance : 24062
I'd love to see the healthydrones log file on this crash.
2017-3-21 05:21:37
SkunkWerxs
Student Pilot
Flight distance : 43542
Unbelievable flaw leds to epic crash ???????????????????????
Sorry to hear about your CRASH but calling it a FLAW is worng
Flying, In and Over such a heavily congested area is asking for a problem --- Look at all the satellite dishes on the terrests of the buildings not counting the cell phone repeater antennas on top  --- Perfect for split second interference and loss of control.
You increased your chances 4x of a mishap by doing so --- good thing no one was hurt
2017-3-21 05:29:46
geofox784
Student Pilot
Here is a guide of how to sync the log. Shouldn't take more than 5 min. https://healthydrones.com/sync-app-ios?instr=1
2017-3-21 06:30:10
jeebs-9
Hobbyist
Flight distance : 8858
Was the drone in sports mode?
2017-3-21 06:44:31
hallmark007
Ban Posts
2017-3-21 09:49:36
fans453b768c
Beginner
Ex Machina Posted at 2017-3-20 19:20
I was not on sport mode, thanks for the kind words.
2017-3-23 23:01:01
fans453b768c
Beginner
DJI Mindy Posted at 2017-3-21 02:41
About to discuss that right now.
2017-3-23 23:02:14
fans453b768c
Beginner
hallmark007 Posted at 2017-3-21 09:49
I have a feeling more and more of these videos are just click bait.
What? Please explain. You are accusing me of crashing my 1,2k drone into a building to - get clicks on youtube?
2017-3-23 23:12:59
hallmark007
Ban Posts
2017-3-24 00:40:42
DroneFlying
Intern Pilot
fans453b768c Posted at 2017-3-23 23:12
Well, it is a fact that you did the following:
  • Posted a video that seemed to be intended to elicit sympathy, implying that the crash wasn't your fault and that you were denied a (free) warranty repair by DJI.
  • Asked for, "any hints how to avoid such situations in the future".
The problem is that without the flight log information nobody here can offer much sympathy or meaningful advice beyond "don't fly near buildings", which is essentially what you said you were already told by DJI. And yes, I find it a little strange that even after several days and multiple requests you still haven't provided the logs, especially considering that doing so would require only a fraction of the time it must have taken you to create that slick video.
Historically, most I-crashed-but-it-wasn't-my-fault claims on this forum turn out to be pilot error, and without the logs most of us are going to go with the odds and assume that yours is just another example of that.
2017-3-24 04:06:17
Impact9
Hobbyist
Flight distance : 40305
From my understanding you are not suppose to fly the mavic indoors, around bodies of water larger than a tea cup, near trees, grass, tall shrubs, bumps in the road, buildings, dog houses, people of any size, in outdoor environments that exceed 400ft in altitude, nor while temps are below the freezing point of lead as it may cause your drone to fall from the sky. You must monitor solar radiation as it may possibly make batteries suddenly error out causing the drone to be taken over by 3rd party microwave ovens that are not in use at ground level.  If you stood were someone else has stood in the last 2000 years as it could cause interference as well.
Yes I will bitch, My drone flew away and crashed and it wasn't my fault. DJI has had it for 2 weeks now and still have yet to provide any insight or update my repairs status.
2017-3-24 10:55:50
SkunkWerxs
Student Pilot
Impact9 Posted at 2017-3-24 10:55
Impact9,
Your too quick to claim a FLYAWAY in your post and supporting a person that refuses to provide a copy of the Flight Log !!! I understand DJI has obtained your Flight Log That you provided to them and DJI has found out That your so called FLYAWAY was PILOT ERROR!!!!!!!!!!
I find your Post to be Exaggerating Nonsense and Full of False Statements !!!!
Causing other good pilots to worry !!!
Learn to Accept Responsibility for Your Electronically Recorded Proven Actions !!!!!!!!!
CAS-485607-Q9Y3D2
Your case says fly away and operator error and you want a refund.
I reviewed your flight and I only see you at 3.3ft and they you went 100% full forward and let off a little before the tree and the aircraft slowly slowed down but not fast enough and you ran into the trees on the edge of the wash. There was no reverse input given to assist in the stopping.
        BOOM
2017-3-24 16:55:00
SkunkWerxs
Student Pilot
Impact9,
CAS-485607-Q9Y3D2
        BOOM
2017-3-24 16:55:30
Impact9
Hobbyist
SkunkWerxs Posted at 2017-3-24 16:55
Impact9,
What I found is many of the so called "experts" are quick to throw pilot error out there on post that don't have a concrete backing of the flight log. Then if the OP don't understand how to get a flight log uploaded, this group of people takes credit away from the OP's account of what happen. Thus, it must be pilot error if no flight log is shared with the world. So Expert, explain to me why my drone went left and up uncommanded (that IS a flyaway) had it not done this my throttle commands wouldn't even be mentioned because it wouldn't have crashed. Period.
2017-3-25 05:09:58
DroneFlying
Intern Pilot
Impact9 Posted at 2017-3-25 05:09
Maybe this comment wasn't directed at me, but for the record I've never thought of or referred to myself as an "expert". I do have opinions, though, and yes I feel as free to share mine here just as you do.
So your theory is that the OP is smart enough to make that video but it takes him 5+ days to figure out how to accomplish something (uploading flight logs) countless others have done with ease? Interesting.
2017-3-25 05:26:20
SkunkWerxs
Student Pilot
you went 100% FULL FOWARD and LET OFF a little before the tree and the aircraft slowly slowed down but NOT FAST ENOUGH and you ran into the trees !!!!!!!!
      Your Log does not state about your AC ever going LEFT or ASENDING as YOU CLAIM!!!!
IF YOU DONT FIND IT STRANGE THAT ALL YOUR STICK INPUTS AND FLIGHT DATA Height and Speed WERE RECORDED 100% FOWARD with LITTLE LET OFF --- NO RC SIGNAL LOSS or INTERFERENCE WARNINGS and the BEST PART of it now is that YOUR CLAIMING THAT THE MAVIC WENT LEFT AND UP BEFORE YOUR STICK INPUTS and FLIGHT DATA was RECORDED.
         Sorry Pal try telling someone else that don't understand the OPERATIONS OF THE MAVIC!!!!!
NOW you try To UNDERSTAND that according to your FACTUAL FLIGHT DATA that is RECORDED from when you turn the MAVIC ON compared to the FAIRY TAIL Story OF A FLYAWAY YOUR GIVING the FORM
YOU WOULD NOT HAVE HAD CONTROLL OF THE AC FROM WHEN YOU FIRST STARTED IT UP!!!!!!!
    Your IGNORANCE makes me look like an expert !!!!!!
   THIS WAS NOT A FLYAWAY it was PILOT ERROR so STOP  all your BULL CHITing  to ppl on this form!!
2017-3-25 06:10:04
12Next >
Close
DJI RecommendsPrevious /1 Next
