dmyers
autopiloton Posted at 2017-3-30 07:06
Yes it is, I currently use Litchi for waypoint missions on my M600 Pro. I do recommend uploading missions after the 600 is in the air. If you start a mission on the ground it gets a bit aggressive with motor starting and liftoff. You will also want to make nice rounded turns in your mission, the 600 will wobble a bit when transitioning through a waypoint if there is little to no rounding of the turn.
Hi, I haven't had a problem uploading missions to my standard M600 with older firmware but I still can't get the latest firmware (that seems to be the same on the Pro and the M600) to recognize when the controller is in F-Mode. The app shows that the controller is in P-Mode and says "GPS" when the controller is in F-Mode. After trying to upload the flight plan is says the controller must be in F-Mode. I recently purchased an M600 Pro and am having the same issue with the app not recognizing when the M600 Pro's controller is in F-Mode. Do you have any suggestions??
Thanks,
D |
