ProQuad
Flight distance : 20296870 ft
Nigel_ Posted at 2017-3-20 16:22
Don't try it at 400ft, I don't think the simulator accurately simulates the high speed fall as the propellers come to a stop and the aircraft goes unstable before the propellers spin up in reverse and stability returns.
If you try it at 500m then it will probably work, but there are a lot of things that can go wrong so make sure that there is nobody underneath at the time!
Yes, I agree that the simulator is not accurate and yes I also agree that it should be up higher. Too many variables for this, but, my theory is that it is possible if everything goes right. |
