GoApp4 bug with android and maps
1028 5 2017-3-21
John94si
Flight distance : 261312 ft
I factory reset my samsung S7 which is a supported device. I only installed mobizen for screen recording and go app4 the current verion. It flys fine but when i press the MAP the app crashes. Once it reloads it now shows google maps instead of HERE. We all prefer google.
*One this is a bug that should be fixed becuase app crashing can be a big issue
*two if google works why cant we choose it as the defualt map?
2017-3-21
bunny too
Flight distance : 13442 ft
All very good questions, you make a valid point.
2017-3-21
CuaC
Flight distance : 369626 ft
I guess the google maps preference is a licensing issue, Google charges for commercial use of their APIs under certain conditions. It might also be an issue with access to the Google Services in China. Probably the development still contains the google maps code in case they solve whatever issue they have with it, which probably is causing other side effects.
I also have an S7 working fine (although as far as I know it's not a supported device according to DJI) I would suggest to install the Here We Go (Here maps  app) as it seems that having the main app installed solves some issues.
2017-3-21
Please try with CuaC's advice and let us know if it helps.
2017-3-22
John94si
DJI Mindy Posted at 2017-3-22 00:58
Yes i installed hERE and downloaded local offline maps and also the same for google maps. No change. It still crashes the app.
2017-3-22
John94si Posted at 2017-3-22 05:49
Please provide me with following information:
1. App version
2. System language and system version
3. Your location
4. Crash log  ( path: /sdcard/DJI/dji.go.v4/LOG/CRASH )
I'll help to forward your information to our engineers for review.
2017-3-23
