Charging hub
1461 9 2017-3-21
borse2008
Unpackaged the charging hub firstly can't get it detected on the dji assistant computer app. For firmware ? Any ideas.
So wanted to charge the 2 extra battery's are both batteries meant to charge simultaneously?  The second one isnt showing any leds. Any tips.
2017-3-21
Thudd
Flight distance : 1624787 ft
One at a time
2017-3-21
Ex Machina
Flight distance : 1806362 ft
Plus your RC, which is immediately charged.
2017-3-21
PimpDawg
Flight distance : 1204754 ft
What is the difference between the charging hub and the advanced charging hub? DJI's website lists their specs and charge times as identical so I don't see a difference other than price.
2017-3-23
SkyMavic
Austria
Your hub will always charge the fullest battery that you can go in the air fast again. It will always just load one after the other...
2017-3-23
jreynolds5
Flight distance : 535341 ft
There is the smart charging hub that will charge simultaneously.
2017-3-23
DJI-Ken
Flight distance : 1515312 ft
PimpDawg Posted at 2017-3-23 10:08
Charge times are not the same.
Mavic Charging Hub M1CH-S:
5 hr 10 min (Mavic Charger)
4 hr (Mavic Car Charger)
Mavic Charging Hub (Advanced) M1CH-P:
4 hr 10 min (Mavic Charger)
3 hr 15 min (Mavic Car Charger)
2 hr 30 min (Phantom 4 Charger / Car Charger)
2017-3-23
PimpDawg
Thanks. Seems like the lesser charge time has more to do with the use of a Phantom 4 100w charger being used with the hub than the hub itself.
2017-3-23
Silverado101980
Flight distance : 5858166 ft
My advanced hub will charge the battery with the highest charge but when it enters the 4 green dot the next in line starts up you get two yes but only when the battery ahead is finishing up I use the 50w charger 4 batteries at 25% and the remote is anround 3 hours or slightly longer
2017-3-23
fans09a1dc10
Has anyone uses the phantom4 car charger with advanced hub? Does it work well?
If I'm charging on the go that 45 min saving sounds with it, downside being you have to always being the hub.
2017-4-4
