Geebax
Quamera Posted at 2017-3-23 03:44
I thought GPS was nobbled in Atti but upon re reading the manual I observe that the height restriction is still operational and I guess if your height is restricted to zero then your Phantom isn't going to make it off the ground.
All that ATTI mode does is disconnect the GPS position stabilisation system, the GPS is still working and is still used to work out where the aircraft is located on the face of the planet. Therefore it still knows whether it is inside an NFZ. The height restriction is a seperate issue, as height is measured by the on-board barometer, not the GPS system. It is possible to nobble the GPS by placing aluminium foil on the top of the aircraqft to block GPS reception. |
