Mcdudeflut
Flight distance : 243753 ft
I have found some specs differences online.
Full article can be found here
Seven Differences Between Mavic Pro and the Mysterious Mavic S Drone
1) weight: the S version comes in at 3 grams heavier, and it’s with or without the gimbal cover
2) the Mavic S having a battery life that tops out at 25 minutes, versus the Mavic Pro that can last “up to 27 minutes”.
3) the Mavic S has a maximum flight ceiling of 19865 feet, which is 3461 feet higher than the Mavic Pro. 4, 5) the Mavic S lens also has a Field of View (FOV) of 94° using a 20mm lens with a slightly less shallow f/2.8 depth of field. The FOV for the Mavic Pro is listed at just 74° with it’s 28mm lens and f/2.2.
6) the final differences are in the framerate for recording video and the battery voltage of the remote controller.
FHD or 1920×1080 recording mode can go as high as 120p on the Mavic S, but tops out at 96p on the Mavic Pro. The reverse is true for HD recording mode at 1280×720: the Mavic S tops out at 60p while the Mavic Pro takes it right to 120p.
7) Operating Voltage in the Mavic S remote control is listed at 700 mA. In the Mavic Pro it’s 35% higher at 950 mA.
The great ununswered questions remain: Is the Mavic S actually going to be produced or was it just a prototype for the final Mavic Pro that we have today?
