thehippoz
M Stuart K Posted at 2017-3-24 10:18
Cold; I would say on the water it was between 32 and 35. Are you saying that the device anticipated continual battery loss when it got to 20 percent and shut down. I did have the screen wide open brightness when it happened. What about my 6 Plus when it shut down at 65 percent. Thanks for your comment on temperature because I had not considered that yet, but I do remember flying longer in colder temperatures with my ipad but it was with the P4.
With lion, there's a point when running them in series where the voltage sags. On a microcontroller, you have something called a adc you can check voltage with. Resolutions differ chip to chip, and sometimes you need to design in a voltage divider for high voltage monitoring. But basically it converts the voltage into a 8 or 16 bit number. Like in custom lights that pull a lot of amperage, you hit a point usually around 3.1~3.3v per cell where the cells can become a bit unbalanced. When this happens, the cell that's lower than the others will act like a vampire and the demand gets higher on the other cells.
In the adc, you will see a dip in voltage lower than the safe cut off. What I do is, every 62ms interrupt is check the adc for voltage but it must trip low 6 or 7 times to make sure it's not a sag. What's probably happening in the ipad is one cell has lost capacity and when it hit's around 20%, the sag is showing shutdown voltages to the adc.
You can recover some capacity by discharging slowly to shutdown and recharge fully 3 times.
Also should note, in litchi, you can set one of the buttons like c1 or c2 to home lock on hold or set the home point at rc. If that ever happens you can still fly it back without rth with the home lock or if you've moved, set the new home point and rth (haven't tried that one myself, not sure if it would set without phone gps or not). Least with older version.
