Trent Mavic
Flight distance : 1098924 ft
Landbo Posted at 2017-3-24 03:47
Yes, it is you actually need to do if you are accused of something you have not done. And it does not look good if you view your electronic log on the tablet with a lot of flights where the nearly headline says you have exceeded the height multiple times you must fly. And I can say hello and tell you the 41 meters height I have mentioned, is nearly the highest point here for many kilometers. Denmark is a flat country here where I live.
There is no danger of I come and fly near the White House or the British Parliament, not even the Danish.
Ok but nobody in real life is going to come up to you after watching you fly your drone and accuse you of going over 400ft just cause it looks high.
As jreynolds5 said, most people don't keep to the LoS and 400ft. I personally don't and that's a risk I take (That I can see is clearly minimal as long as you're sensible with regards to aircraft)
Look at it this way. With much higher consequences, how many people who have a driving licence knowingly exceed the speed limit be it by 1mph or 10mph? Consequences are much much higher in terms of damage/life/your licence/fines etc yet if you could truthfully find out, I bet you, 99.9% of people have done it, if not 100% |
