Cabralkev
Flight distance : 1997861 ft
freelanderuk Posted at 2017-3-24 00:52
My motors have a tilt on them also so much that the landing gear legs scrape the side of the case when I put it away, I have only just bought it ,I saw it flying and all seamed well ,taking it for my maiden flight today so will see how it handles ,
I have raised and lowered the landing gear and it always seams to go back to the same position, so I thought this may be ok, when on a total flat surface the feet of the landing gear are at a slight angle and not totally flat on the surface, is yours the same
Yeah sort of the same. There is a tilt and when you put the Inspire on a flat surface, you can see the landing gear doesn't sit flat. I even tried grabbing the end of the boom arm where the motor sits and tried turning it. Was thinking maybe it was loose. It never budged at all so I figured the tilt I saw was normal. It seems the only 2 arms tilted slightly more than the other 2 arms. My assumption it was normal because the thing wasn't loose. |
