Donnie *
Flight distance : 3636782 ft
I would , just add tiny drop more , can't hurt anything . Just use sparingly as a little goes a long way .
The foam blocks go inside the props , I would do some test fitting though first , some are saying that only the red ones need it , some are saying dont need it at all just use a shim of electrical tape .
Go the the near top of the thread for some good debate on which to use , it is under the 1345 ls mount plate thread .
I personally custom cut my foam inserts to make each one fit perfectly . If it gets to tight it could crack that pressire ring . I personally find this a terrible idea from DJI, My other prop system worked just great without having to shim etc. I thin this was a matter of them getting shipped some bad props from a vendor and did not check the specs, then after some complaints had to come up with something .
donnie
