Dog Man
Flight distance : 34380 ft
Mobilcams Posted at 2017-6-24 12:52
I think the actual action saves the gimbal from damage because it has approached the maximum it can tilt. If it tried to go any further it would burn out the motors.. Try this with it on the ground and you will notice that it will actually level out in relation to the tilt itself (not the actual position of the horizon).. If there is a lot of wind from the side, the Phantom will correct it's position by tilting into the wind.. You won't notice the tilt from the ground because it's difficult to see these angles from the ground (unless ground wind speed is high as well)..
Know problem, DJI, will need software update to fix it or hardware, problem started with the P4 in sport mode. |
