GabeZ
Flight distance : 768448 ft
Hi fans03f8707f,
If you look at the latching portion of the battery, does all look ok? Nothing broken off? If you then look at the track and latching portion of the aircraft, does all look ok? Nothing broken off? What if you swap batteries? Any difference at all? When you press the release button, do you see or feel anything odd? Does the outer ring and inside pin of the release button seem to operate normal? When you try to latch the battery, does the release button move at all? If you press the release button down, and then push the battery into place, are you able to get it to latch then? |
