fansa2e387b9
Hi, the search function of this forum is terrible. Is it me?
I'm sure it's a known issue. This is a major problem and DJI doesn't talk about it.
During a flight, using the Phantom 4 Pro+ and the remote controller built-in screen, the DJI GO app will crash from time to time. During a flight.
When it happens, you need to restart your remote, while the unit is in the air. Very dangerous and if you can't do it fast enough, the Return to Home feature will happen, even if you were flying safely between trees or any other obstacle. So obviously, the phantom 4 pro+ will go up in the air (because the RTH activated itself), you panic because the DJI GO app has crashed at the worst moment and you have no video signal (black screen, app crashed).
I read the firmware update notes, and it's still not fixed, no one talk about it. Are you dealing with the same issue?
