Cetacean
Flight distance : 2528264 ft
Aloha tim,
It looks like you are between a rock and a hard spot. Without another battery, to see if your current battery is faulty, you may need to send your P4 Pro in for evaluation. With all your excitement, I am sure that this is not a welcome suggestion.
Is there a store or repair location near you that has DJI products? They may allow you to try to test your system to see if all you have to do is send in the battery alone because it is faulty.
In lieu of that, did your P4 Pro have any need to be updated to 01.03.0418 other than the suggestion from the system? Maybe you can downgrade the system to the earlier firmware and see how well it works. This can be done in Assistant 2. If it works, you would not want to fly your Phantom too long before you try to resolve your battery problem because it would be dangerous.
So many questions, so much need for answers. That is the nature of cutting edge technology. On the up side, many people want to help because it is cutting edge technology.
Hope this helps!
Aloha and Drone On! |
