hallmark007
Flight distance : 9827923 ft
No you shouldn't need to calibrate compass , unless you are prompted. There is a great danger if you are getting ready to fly and you receive a warning like magnetic interference please calibrate compass, if this is the type of warning your getting. You should not calibrate but move to another area where it is clear of interference like an open field, if you still are getting a warning here it is most likely you have calibrated your compass in an area where there was interference and your compass has taken on the peculiarities of the area you have calibrated your compass, so when you fly out of these areas you are in danger of having a bad compass.
How to solve this.
1/ take your AC into an open field
2/ make sure no metal objects, reinforced concrete remove your watch jewellery phone and any other metal objects you might have on you, also keep remote control distance of 10 meters away.
3/ turn on your RC and AC and preform compass calibration, when you have finished check in the app your compass reading make sure it's ok, if not you will have to do again.
4/ you shouldn't have to do anymore calibration unless prompted by your app
5/ if you get a warning before take off of interference, Don't Calibrate, just move your AC to a location where there is no interference.
Interference can come from many things, Steele metal reinforced concrete all magnetic metals.
Hope this helps. |
