hi
just been out for a flight and checked my props for play and one mount has some up and down play in it
do i need to locktite them ,and do you tighten them right up tight
thanks
Loctite should not be used around plastics. It can stress crack them. Motorcycle windshields have been known to break in half around the mounting holes when it was used on them against the wind.
Don't get them too tight, and do use a permanent marker to draw a line across the top onto the plastic so that you can easily check if they are loosening every time you mount the props.
