Please fix Z3 already!
1549 14 2017-3-25
P3T3
Flight distance : 701211 ft
Been neglecting Inspire over the Mavic for a while now. Just did all the recent firmware and DJI has yet to correct the left wheel (up/down) control for the Z3. It still moves the camera left/right. What's the deal?? Is it that big of a problem to change how this behaves? I've called numerous times last fall and was told they're aware and releasing a fix very soon. Still the same. X3 functions as it should. Please someone from DJI respond
2017-3-25
Mark Guille
Flight distance : 2031818 ft
Jersey
I am assuming you have set the C1/C2 button to toggle camera tilt/pan?
C1 and C2 customizable buttons functions
Mark G.
2017-3-25
P3T3
Mark Guille Posted at 2017-3-25 12:49
Thank you, no I had set to autocenter and change camera mode. I don't need those as much as I need to move up and down. PIA to be using finger. I'll make those changes until they fix the issue.
2017-3-25
P3T3
Now that I got around to changing C!/C2 the wheel is working up/down as it should! About time, but thanks DJI
2017-4-5
P3T3
After flying Mavic and Inspire fitted with Z3 it really shows what a POS the Z3 is for filming. Lag, pixelation, weak signal c'mon DJI. That camera cost as much as my Mavic. Put some effort into it. Also please allow the inspire1 onto DJI GO 4 app. At one location I could only fly the Mavic because DJI Go app still has this defunct airport as active and wouldn't allow me to takeoff with Inspire
2017-4-5
DJI-Jamie
Flight distance : 112405 ft
P3T3 Posted at 2017-4-5 15:23
Just to clarify, what firmware and Go app version are you on? What mobile device do you use?
2017-4-5
Mark Guille
Jersey
You have informed DJI about this airport? When I emailed them about an error with my local airport, the amended it within 24 hours.
Mark .G
2017-4-5
P3T3
Mark Guille Posted at 2017-4-5 21:40
Mark .G
I did, they referred me to FAA, they advised me that the town that own's the property needs to change it's status. But now with GO4 app it allows me, regular GO, no go.
2017-4-6
P3T3
DJI-Jamie Posted at 2017-4-5 16:44
iphone 7 running latest firmware and GO apps. DJI GO won't allow takeoff for Inspire1. DJI GO 4 app for Mavic allows flight.
2017-4-6
DJI-Jamie
P3T3 Posted at 2017-4-6 07:23
Could you happen just to verify the Z3 firmware you have? In addition, the latest iOS Go app update had a server issue when downloading yesterday, could you happen to reinstall that as well?
2017-4-6
P3T3
Here's screencap of fw
2017-4-6
P3T3
Looks like my bad for now.... Z3 updated when I hooked it up to Osmo, but that was only it's update. I'll put latest on and see how it goes after that. Still apprehensive about it changing takeoff location bc I think thats restricted to older dji go app.
2017-4-6
P3T3
Now this is the txt after trying to add latest fw
========== 2017.03.25 14:57:42 remo-con disconnect======
Packet: WM610_FC350Z_FW_V01.10.01.40.bin
Upgrading ...
Result: Success.
========== 2017.04.06 16:13:41 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the device.
So I was up to date, but why does phone connected display otherwise?
2017-4-6
DJI-Jamie
P3T3 Posted at 2017-4-6 12:28
It does have a "+" at the end of the camera firmware version listed. That normally means that there is a change in firmware, but the DJI Go server is having some delay updating that information. From what I see, the RC might need to be updated, as I believe it's on 1.8. If you see the pop up again, could you happen to take a screenshot of it so I can see what it indicates is out of date?
2017-4-6
P3T3
There's no message saying remote is out of date though? Wouldn't it prompt to update fw?
2017-4-13
