seeker_ktf_
Flight distance : 218474 ft
Mexico
I have an S7 (marshmallow) and as far as I know you can't disable charging. The best you can do is turn off the fast charge, but it's not clear how much that helps. If you look at the battery graph after a flight you can tell it's not charging full on anyway. The only other solution is to use a cable to the USB port on the underside of the controller. That will not charge the phone and doesn't look all that bad. I have a coiled cable I usually use in my car, and that works fine. Somehow the coiled cable looks more like it "belongs" in the setup anyway.
Ether way, I can fly through 4 batteries. I feel like without the charging on, my phone doesn't get as warm, so maybe that matters. It's hard to believe that the controller could loose 80% of a charge in only 30 minutes even if it was charging the phone as much as possible. Maybe it's a dud? |
