tofutim
Punchbuggy Posted at 2017-3-26 16:45
Mobilcams, starting up the app to see if the battery is compatible is Not the only way - albeit it might be in the field. Assistant 2 when connected will advise if the battery is 'incompatible' and suggest to refresh the firmware (which you'd do if you want to use that battery). I NEVER upgrade my P4 or P4P via the app/RC, as that incorporates another link in the upgrade process. I also perform updates as soon as Assistant 2 recognises the craft once the craft has finished powering up. This ensures the craft is as cool as it can be, and I've never had an issue after upgrade, as I've read on this forum.
Otherwise, Tofutim, your app shows 'invalid battery'. Was this the original battery received with the P4P, or another? Have you tried to refresh the P4P firmware (with that battery installed) via Assistant 2 and directly-connected PC? That way you may avoid the GO app trying to add a layer of interpretation to what it thinks it's seeing (or not, as the case).
I cannot refresh or downgrade in Assistant because it says the battery is lower than 50% (it detects nothing, but the battery is fully charged). I believe that the problem was that I originally tried updating through the DJI Go app as it prompted me on first flight.
Sadly we have yet to fly. |
