TB-47 Broken Cell error and fix
2496 4 2017-3-26
fans7c32557f
Flight distance : 1500794 ft
Austria
Hi Everybody!
After about 40 charges two of my TB-47 batteries showed the "Battery Cell Broken" error message. As I am out of warranty I gave it a shot and tried to "fix" the battery myself.
It turned out that the root cause of this error message is a too high cell voltage variation. I don't know why but unfortunately the battery firmware is not able to balance out this cell variation during recharge. So I decided to try to "manual balance" my battery cells and it turned out that this seemed to do the trick. My batteries don't show this error message anymore and can be fully charged again. I am aware that the error message might come back but for the time being it looks good.
As this might be helpful to others  I have written a detailed description on how to manually balance LiPo cells on my blog.
TB47 Broken Cell fix
Cheers,
Marco
2017-3-26
freelanderuk
Flight distance : 177720 ft
Thanks , I have the same problem with a TB47 battery
2017-3-27
Marco
Austria
freelanderuk Posted at 2017-3-27 00:00
...please let me know if it worked for you as well
2017-3-29
Marco
Austria
Marco Posted at 2017-3-29 00:16
Just a little Update: The above mentioned battery fix seems to work permanently. I've meanwhile run a few battery charge cycles and the TB-47 batteries continue to work fine
2017-7-4
robyr1
Please fix the link wich is broken!
2022-8-9
