I did an upgrade of firmware om my P3 Std and i have tryed to reebot Aircraft and i still not work and dont get the upgrade Icon in my mobile device anymore so i cant retry upgrade, what to do ?
Right now the version is unknown and i used my apple mini when i uppgraded it
The Aircraft just sounds "beep""beep" countinusli all the time.
I have checked the file that was downloaded on the SD-Card and its P3C_FW_V99.99.9999.bin
Some modules are not detected according to the log.
Please try another mobile device or delete the APP then install it again on your mobile, format the SD card, then connect them properly and check whether it asks you to upgrade it again.
If no icon popping out, it may needs to be sent in.
Here is what worked for me. I attempted to update the firmware. Part way thru I got a message that the attempt failed and I should retry the update process. Upon restarting of the aircraft I got a loud repetitive alarm and no prompt to update the firmware. My solution was to turn off the aircraft and controller then reformat the SD card. I deleted the DJI go app and reinstalled it on my same device. I then turned on my controller and activated the DJI app and kept connected to my local wifi not the phantom wifi signal. The first screen on the DJI app will show a selection for the Inspire Drone. Swipe left to reveal the choice for the phantom standard. At that point you should get a prompt for the firmware update. Start the aircraft. It will continue to sound the alarm. Hit the update option on the DJI app and the firmware will reinstall. It may take about 5 or 10 mins. When it is finished the alarm will stop and you should get an update success message. If you try this while connected to the phantom wifi signal you will not get the firmware update prompt. I first had a text chat with a DJI rep and they concluded I had to send it in for repair. Please try again using this procedure hopefully it will work for you too. Good luck.
