Donnie *
Flight distance : 3636782 ft
But did you try to enter travel mode with the Camera on the aircraft ? If so try my suggestion in post #2.
Did you also update the RC ? Is the X5 the only thing that has failed or have you lost all communication between the AC and RC .
Did this happen immediatly after the update ?
**** You are not trying to operate the X5 while in Travel mode are you , Just want to make sure I understand . What you are saying is that since you updated you had the system working fine , but since then you went into travel mode and now the X5 camera wont work anymore , is that correct ?
Does the camera do the start up dance when fireing up the system ? Is it that you dont have any video but all else works fine ? Can you take pics and video with your Camera ?
If all else works, you can start the motors, the camera does the start up dance , you are on compatible firmware for the AC RC and Cmaera , and take pics and video then keep reading , sometimes after updates the "Video module" can get corrupted
****Need more info , the putting the travel mode my be a red herring , the X5 camera if not getting any video after the update may be becasue of a corrupted video module . If you think this could be the case place the SD card ( the one you did the update with ) with the last update in the computer and look at the Hidden file , If lines 0800 and 1500 say device not detected than thats the problem .
Below is a link to viewing the SD card hidden file , only do this if you think the aqbove may be true.
http://forum.dji.com/thread-44544-1-1.html
donnie
