r4nd0m
Flight distance : 839055 ft
hallmark007 Posted at 2017-3-27 01:35
Did you loose gps, if you just lost Radio it should start RTH it just depends on what setting you had for RTH , there are ways of getting your coordinates from your app , how did you know it was upside down on the rocks?
Your best bet to get some info on what happened, is to post your logs here, and as Mindy says sync your flights.
Crashes are always tough loosing your AC make them worse so hopefully you might get some help to find it.
it should not be an issue - in fact when I was bored to fly the model (Phantom2/Inspire) back from the point it was recording I just switched off the remote to have it return to home and it should without any issues ...
what I have read recently on the forum though, there seems to be an issue with the obstacle avoidance if the Mavic needs to climb quickly, especially seen when the Mavic needs to avoid an obstacle while flying uphill - this seems to be an issue ... another option could be that the Mavic tried to land itself but due to landing uphill flipped over ...
but again, this should not happen in the first place |
