Marcial Manuel
Thailand
RicardoGray Posted at 2017-3-27 07:15
Just trying to help here. So, to be clear your gimbal is completely dead, right? Does not do the "dance" upon startup? No light visible on the camera.....red , green or nothing? I know you said you checked the cables, it sounds like you must have a 3PA or the pro, not the standard. If all looks good from the gimbal side of things, you may have to dig a little deeper. You might have to take the top shell off and look at the connections on the main board. You said it didn't break anything but admitted it took a light crash, it may have jarred something loose inside the shell? Did you take the back off of the camera and check that connection inside there? Also the gimbal motors? I think you checked the cables plugging into the gimbal assy. from the phantom, but you might have pulled one the ribbon cables out of the socket on one of the motors, those are not as easy to see without some disassembly.
Hi. Thanks for your help!!
Phantom 3 professional. Completely dead yes, no lights, no dance.
I will definitely investigate further with some disassembly.
Might get back at you, thanks again! |
