JBSonic
Flight distance : 779019 ft
For this I dont think we are really looking for software faults as these can easily be removed with software updates, please disregard those.
What you want to look at are hardware faults, these you cannot change unless replaced.
The Mavic does not seem to have hardware issues, I have one and have been flying it for around 4 months now.
I imagine the Phantom series is fine too since there have already been so many iterations of it, no reports of hardware problems.
Inspire 2 is different, I have one and all the propellers rattle (on the front left motor), of all the things that could be wrong, it is the propeller mounts.
The Inspire 2 propeller mounts (v1) are faulty and MANY have rattling propellers as a result.
This is not much of a problem for most, but it can cause vibration if it is TOO LOOSE, this has resulted in some crashes for some users so far (keep in mind still a small percentage of all active Inspire 2s).
But still, the Inspire 2 as is right now has faulty mounts, the V2 propellers (with the foam inside) are NOT a solution to the problem.
The Inspire 2 requires ALL NEW mounts to remove this problem.
For this reason, the inspire 2 certainly has the most issues, despite being by far the most expensive of them all. |
