hallmark007
Flight distance : 9827923 ft
I see from your logs from airdata that a 1.36 you reached max height you continue to fly higher, 469 feet, then you were behind the mountain and signal cut out because your RC had no line of sight, it looks like Mavic might have been returning home and it looks like OA did work but because of it having reached its max height it couldn't go higher to clear first obstacle, so procedure with Mavic is to fly around obstacle which it looks like it tried to do, but because it was now flying at an angle and not straight on and also very close to second obstacle which narrows the sensing view, OA didn't work a second time. My guess..
At some time in the flight you were trying to adjust a setting, was this sport mode or height restrictions.
