The Tab S2 will NOT connect to the controller when using the Davic!
The Go app just refuses to connect when using the Davic. If I use my P4 with the Tab S2 and Go everything connects.
S2 settings: Developer options if I choose USB to use MTP, I get a popup that asks if I want to use Go as the default program. Unfortunately, this immediately goes away and then pops up again. Over and over. It is not on the screen long enough to allow me to make any selection.
I can see that when it pops away the USB port is changing to Charging. Then when the requestor pops up the USB port switches to MTB, then away over and over.
If I choose RNDIS the app never connects to the controller.
Bottom line is I cannot use the Davic with the same tablet that works fine with the P4.
Tab S2 is using Android 6.01 and the Davic and controller are using the latest update vxxxxx500
Side notes: Same controller, same USB cable but using my Galaxy Note 4 cellphone everything just works. Never need to make a USB function selection.
Also, the Tab S2 works fine with my P4. I do have to choose USB function as RNDIS for the Phantom.
