DroneFlying
Flight distance : 10774613 ft
If I understand correctly, you're you're trying to use the USB port on your Mavic's battery charger to charge your Mavic's remote control but it won't charge; is that correct? If so, have you tried both of the two USB ports on the charger? If one works but then other doesn't then the one that doesn't is probably defective. If neither works then my guess would be that the USB cable you're using is defective, and you should try charging using a new cable or one that's known to work. |
