aircrafts are swaped in djigo3
fansccabc25e
Peru
Is this  normal???
2017-3-28
Cetacean
Flight distance : 2528264 ft
Aloha fansccabc,
     Yes, this is normal.  You need to slow down and try to figure out what you want to do.  What is your Phantom model?  What is your device?  Is DJI breathing down you neck to upgrade firmware?
     But, just slow down and take your time.  Figure out what you are doing and then do it.  Reading the manuals is the best thing you can do, mostly because it gives you an understanding of the technology you are using.  Do not worry about doing a firmware update until you are bored with what you are doing presently.  Then the update will open up new horizons.
     In your thread, you are concerned about being presented with a choice.  Pick your model Phantom, and then proceed on.  It really is good fun!
Aloha and Drone On!
2017-3-28
kndll
Flight distance : 930161 ft
minor bug when only using the app , go by model name ,   when fully connected with model showing and camera button in blue the picture is correct
2017-3-28
DJI Natalia
Flight distance : 318 ft
Please turn on remote, aircraft and connect your mobile device to the remote and run APP, the "Camera" button will be blue.
2017-3-29
