Donnie *
Flight distance : 3636782 ft
andygb Posted at 2017-3-29 22:13
Hi Donnie thanks for answering yeah tried resetting the controller and then reconnecting back the inspire. Changed tablets,leads and even changed master and slave controller rolls and still same issue. Am out of ideas but weather permitting this weekend will reset both controllers reconnect again. The thing is i have the z3 and x3 and it happens approx 600ft out on both cameras. Even thought of sending it back to dji but only want to do that as a last resort. But having the missus nagging me because she losing picture is enough to drive a man to sending it.
Have you tried making slave master and master slave and re test ( On the RC transmitter's , Not the Go app device's ) , if the video now drops out on the master ( formerly the slave ) then you know it is the RC transmitter causing the issue, Maybe the Antenna connection to the mother- board or possibly a bad part 94 on back RC, the HDMI module .
Below is a nice diagram that shows how the Video and control signal works . Like I said 9-10 it is the go app device but with your due dilligance , you may be that 1-10 and have a bad part somewhere on the slave RC.
Also some tips below for better distance , dont htink it will help the defective Slave RC though , but worth a try
When you get at the 600 foot mark and beyond be sure to keep the AC orientated so that it is pointing directly at you or away from you , the antennas are NOT located on the side of the aircraft and range can be greatly diminished in fringe areas if not pointing directly at you or away , keep the Transmitter high in the air , make sure not pointing down , and pointing at the AC at all times .
Can you get at least 3/4 of a kilometer with just the Master RC ? Or farther ? Just want to make sure not an antenna issue On the Aircraft . If you get good distance with just the master we know that the AC antennas are Ok.
If your test confirm a bad RC slave transmitter then I would look at the Antenna solder and connections, and possibly a bad HDMI module that is failing . If out of warrenty I would take the back cover off and inspect and inspect the wiring from the antenna to the mother board . Also at the base of the antennas as well, the right antenna will have 2 wirres that you can see in the base of the antenna, one is for the AC and the other communicates 5.8 to the master RC, the antenna on left is for the AC only , make sure they are still frimly in place and not broken , crimped etc.
Just want to eliminate all other possibilites so you an focus on a fix.
*** You could also take the HDMI module off the good RC and place on the Faulty one and see if it clears up, this would further narrow down the problem . ONLY do this if you have confidence that you are not going to break it and are handy with stuff like this . I have done several of these for friends and it is simple but you must have steady hands and the correct tools, they are not expensive and are at any hardware store , just need to have the correct ones. If you lived In my area I would be happy to do it for ya, but since you are over the pond that might be a bit of a long swim for me.
*** When loosing the picture on the slave go app device does the HD bars show a decrease in strength ? , this would be indiciative of a antenna problem on the Slave RC if the MASTER shows no such decrease , Like in the diagram the video is sent INDEPENDENTLY to both the Slave and Master , If this is the case where you lose signal to the slave RC but the HD bars are strong then I would suspect the HDMI module on the Slave RC.
Good luck
donnie
