tseng
Daroga Posted at 2017-3-28 12:24
Within your attached UpdateLog.Zip is a log file named WM610_FW_LOG_AB.txt. This appears to somehow be an Inspire update log, as WM610 is an Inspire, and the download firmware file is 37480328B in size (almost twice the size of the Mavic). The log complains of a header error, which would happen if the system is trying to load Inspire firmware...
1) Any explanation of how or why the WM10 log file is attached?
Hi.
i don't know why the filename is called like the Inspire Log-File I get this file from my Mavic sd card \MISC\LOG\
Today i tried another smartphone with a new installation of DJI GO4 App with the same result ... I also tried to reinstall the DJI Assistant 2 and upgrade to 01.03.400 also with the same result ... no way to upgrade the firmware of my mavic
New Log Entrys from today
[00280976]========== Download: 2017.03.28 21:30:23. boot(1B3D) =======
[00281042]Master [10 02].
[00281110][29 00] Firmware download start...
[00315800][29 00] Firmware download finish successfully.
[00315867]Done (37480328B 0x7981975f6ad1ba20005a198ed7721a4c).
[00322287]========== Upgrade: 2017.03.28 21:31:04. boot(1B3D)============
[00322357]Current version: loader[02.04.0385] firmware[02.04.0385].
[00322423]Firmware [A:\FC220_SEFw.bin 0x7981975f6ad1ba20005a198ed7721a4c] detected, card sn [0x9310524a].
[00322491][29 00] Firmware upgrade start...
[00322561][01 00] Firmware upgrade tracecode 0x00010000
[00322629][01 00] Firmware upgrade tracecode 0x00020000
[00324164][01 00] Firmware upgrade tracecode 0x00030000
[00324233][01 00] Firmware upgrade failed at header check! [00324302][01 00] Firmware upgrade tracecode 0x0f030106
[00324372][29 00] Firmware upgrade finish failed (step = 2, err = 0xff).
[00327437][29 00] Firmware upgrade finished failed.
[00329124]Done.
[00007761]========== Download: 2017.03.28 21:31:22. boot(1B3D) =======
[00007834]Master [10 02].
[00007904][29 00] Firmware download start...
[00041542][29 00] Firmware download finish successfully.
[00041613]Done (37480328B 0x7981975f6ad1ba20005a198ed7721a4c).
[00048293]========== Upgrade: 2017.03.28 21:32:03. boot(1B3D)============
[00048363]Current version: loader[02.04.0385] firmware[02.04.0385].
[00048430]Firmware [A:\FC220_SEFw.bin 0x7981975f6ad1ba20005a198ed7721a4c] detected, card sn [0x9310524a].
[00048498][29 00] Firmware upgrade start...
[00048565][01 00] Firmware upgrade tracecode 0x00010000
[00048632][01 00] Firmware upgrade tracecode 0x00020000
[00050274][01 00] Firmware upgrade tracecode 0x00030000
[00050343][01 00] Firmware upgrade failed at header check! [00050412][01 00] Firmware upgrade tracecode 0x0f030106
[00050480][29 00] Firmware upgrade finish failed (step = 2, err = 0xff).
[00053549][29 00] Firmware upgrade finished failed.
[00055237]Done.
[00011937]========== Download: remo-con disconnect. boot(1B3D) =======
[00012008]Master [10 02].
[00012078][29 00] Firmware download start...
[00045917][29 00] Firmware download finish successfully.
[00045987]Done (37480328B 0x7981975f6ad1ba20005a198ed7721a4c).
[00052289]========== Upgrade: remo-con disconnect. boot(1B3D)============
[00052359]Current version: loader[02.04.0385] firmware[02.04.0385].
[00052425]Firmware [A:\FC220_SEFw.bin 0x7981975f6ad1ba20005a198ed7721a4c] detected, card sn [0x9310524a].
[00052496][29 00] Firmware upgrade start...
[00052561][01 00] Firmware upgrade tracecode 0x00010000
[00052629][01 00] Firmware upgrade tracecode 0x00020000
[00054168][01 00] Firmware upgrade tracecode 0x00030000
[00054237][01 00] Firmware upgrade failed at header check! [00054304][01 00] Firmware upgrade tracecode 0x0f030106
[00054373][29 00] Firmware upgrade finish failed (step = 2, err = 0xff).
[00057441][29 00] Firmware upgrade finished failed.
[00059130]Done.
[00007840]========== Download: remo-con disconnect. boot(1B3D) =======
[00007912]Master [10 02].
[00007983][29 00] Firmware download start...
[00041712][29 00] Firmware download finish successfully.
[00041783]Done (37480328B 0x7981975f6ad1ba20005a198ed7721a4c).
[00048284]========== Upgrade: remo-con disconnect. boot(1B3D)============
[00048352]Current version: loader[02.04.0385] firmware[02.04.0385].
[00048421]Firmware [A:\FC220_SEFw.bin 0x7981975f6ad1ba20005a198ed7721a4c] detected, card sn [0x9310524a].
[00048491][29 00] Firmware upgrade start...
[00048558][01 00] Firmware upgrade tracecode 0x00010000
[00048628][01 00] Firmware upgrade tracecode 0x00020000
[00050153][01 00] Firmware upgrade tracecode 0x00030000
[00050308][01 00] Firmware upgrade failed at header check! [00050378][01 00] Firmware upgrade tracecode 0x0f030106
[00050446][29 00] Firmware upgrade finish failed (step = 2, err = 0xff).
[00053516][29 00] Firmware upgrade finished failed.
[00055205]Done.
[00718903]========== Download: 2017.03.28 21:46:35. boot(0F6A) =======
[00718970]Master [10 02].
[00719039][29 00] Firmware download start...
[00752510][29 00] Firmware download finish successfully.
[00752580]Done (37480328B 0x7981975f6ad1ba20005a198ed7721a4c).
[00760295]========== Upgrade: 2017.03.28 21:47:16. boot(0F6A)============
[00760365]Current version: loader[02.04.0385] firmware[02.04.0385].
[00760434]Firmware [A:\FC220_SEFw.bin 0x7981975f6ad1ba20005a198ed7721a4c] detected, card sn [0x9310524a].
[00760503][29 00] Firmware upgrade start...
[00760573][01 00] Firmware upgrade tracecode 0x00010000
[00760641][01 00] Firmware upgrade tracecode 0x00020000
[00762175][01 00] Firmware upgrade tracecode 0x00030000
[00762246][01 00] Firmware upgrade failed at header check! [00762316][01 00] Firmware upgrade tracecode 0x0f030106
[00762388][29 00] Firmware upgrade finish failed (step = 2, err = 0xff).
[00765456][29 00] Firmware upgrade finished failed.
[00767137]Done.
[00007743]========== Download: 2017.03.28 21:47:33. boot(1B3D) =======
[00007814]Master [10 02].
[00007885][29 00] Firmware download start...
[00044423][29 00] Firmware download finish successfully.
[00044498]Done (37480328B 0x7981975f6ad1ba20005a198ed7721a4c).
[00052285]========== Upgrade: 2017.03.28 21:48:18. boot(1B3D)============
[00052356]Current version: loader[02.04.0385] firmware[02.04.0385].
[00052422]Firmware [A:\FC220_SEFw.bin 0x7981975f6ad1ba20005a198ed7721a4c] detected, card sn [0x9310524a].
[00052491][29 00] Firmware upgrade start...
[00052558][01 00] Firmware upgrade tracecode 0x00010000
[00052628][01 00] Firmware upgrade tracecode 0x00020000
[00054179][01 00] Firmware upgrade tracecode 0x00030000
[00054345][01 00] Firmware upgrade failed at header check! [00054413][01 00] Firmware upgrade tracecode 0x0f030106
[00054486][29 00] Firmware upgrade finish failed (step = 2, err = 0xff).
[00057553][29 00] Firmware upgrade finished failed.
[00059246]Done.
[00015813]========== Download: remo-con disconnect. boot(1B3D) =======
[00015887]Master [10 02].
[00015959][29 00] Firmware download start...
[00049534][29 00] Firmware download finish successfully.
[00049605]Done (37480328B 0x7981975f6ad1ba20005a198ed7721a4c).
[00056289]========== Upgrade: remo-con disconnect. boot(1B3D)============
[00056360]Current version: loader[02.04.0385] firmware[02.04.0385].
[00056429]Firmware [A:\FC220_SEFw.bin 0x7981975f6ad1ba20005a198ed7721a4c] detected, card sn [0x9310524a].
[00056499][29 00] Firmware upgrade start...
[00056568][01 00] Firmware upgrade tracecode 0x00010000
[00056635][01 00] Firmware upgrade tracecode 0x00020000
[00058172][01 00] Firmware upgrade tracecode 0x00030000
[00058243][01 00] Firmware upgrade failed at header check! [00058312][01 00] Firmware upgrade tracecode 0x0f030106
[00058383][29 00] Firmware upgrade finish failed (step = 2, err = 0xff).
[00061449][29 00] Firmware upgrade finished failed.
[00063137]Done.
[00008077]========== Download: remo-con disconnect. boot(1B3D) =======
[00008148]Master [10 02].
[00008219][29 00] Firmware download start...
[00042228][29 00] Firmware download finish successfully.
[00042302]Done (37480328B 0x7981975f6ad1ba20005a198ed7721a4c).
[00050347]========== Upgrade: remo-con disconnect. boot(1B3D)============
[00050419]Current version: loader[02.04.0385] firmware[02.04.0385].
[00050486]Firmware [A:\FC220_SEFw.bin 0x7981975f6ad1ba20005a198ed7721a4c] detected, card sn [0x9310524a].
[00050557][29 00] Firmware upgrade start...
[00050625][01 00] Firmware upgrade tracecode 0x00010000
[00050697][01 00] Firmware upgrade tracecode 0x00020000
[00052318][01 00] Firmware upgrade tracecode 0x00030000
[00052389][01 00] Firmware upgrade failed at header check! [00052464][01 00] Firmware upgrade tracecode 0x0f030106
[00052532][29 00] Firmware upgrade finish failed (step = 2, err = 0xff).
[00055600][29 00] Firmware upgrade finished failed.
[00057289]Done.
