AndreWolski
Unfortunately it may be impossible to fix that , you have to make sure that you calibrated the IMU on a perfectly leveled surface, you need a level what I do I check the surface first make sure it is leveled then I also put level crisscross on the motor mounts and double check it that way to make sure it is leveled then initiate the IMU cal and walk away for 5 minutes so you don't make any thumping or stomping as that can offset the calibration..., I tend to hold my breath when I do that lol right after that do the gimbal calibration and try to see if that clears... if that won't help , your bird is not working right, send it away for repairs... |
