theGrindLab.com
Flight distance : 1375846 ft
nmaffei34 Posted at 2017-3-29 09:49
I have not tried to shoot in anything less than 4k, I will try but I should still be able to shoot 4k without the glitching. I have a hard time believeing the camera is broken. This was brand new in the box, I did not drop it, been in the case, gimbal cover on at all times, only used it twice. However, given that the glitches and pixelating is in the same spot, whether or not I view it on the app, or through the SD card on PC, I am starting to wonder if maybe the camera is broken already.
Any other thoughts?
If you run the tests at lower resolution and you don't see the same issue, it might be the speed/quality of your SD card. And no, not every "fast" SD card is created the same. |
