Jason Lane
Flight distance : 260144 ft
Singapore
Yeah, if you're launching from underneath something, or even in a tight space, an RTH landing is probably not going to end well.
If your question is mainly about manually initiating RTH, you could do that and allow the Mavic to get close, but then cancel the RTH and finish the landing manually (and hope the RC doesn't happen to lose signal before you're able to cancel the RTH).
If you're more concerned about a failsafe RTH (eg. RC signal loss), then your best option depends on the nature of your flight. For example, you could set the failsafe option to "Hover" instead of RTH, but if you're planning to fly very far away, and/or over difficult terrain, there's a small chance your Mavic will be left hovering and you're not able to regain the signal because you can't get closer to it. Alternatively, you could leave the failsafe set to RTH, and hope that you're able to regain control before the landing sequence starts, so that you can bring it in manually. |
